I知 lost again, many codes
Old Aug 19, 2024 | 01:44 AM
7eus's Avatar
Solved for now I guess
I tested the resistance through pin 6 and 14 while unplugging and plugging all the electronics. I was getting the normal 60 and 120 ohm readings.
I inspected:
EBCM connector
TCM connector
ECU 3 connectors
BCM 2 connectors
Pushed in all the fuses and relays under hood.
all the pins on the connectors looked good and the wires looked ok where they protrude from their sleeves. I think that replugging things that haven稚 been touched in 14 years fixed it, no symptoms returning yet. Fingers crossed
Old Aug 19, 2024 | 06:51 AM
Maybe tighten those 4 bolts
These 4 , 7 mm bolts.
Old Aug 19, 2024 | 01:04 PM
7eus's Avatar
I知 fairly confident that I tightened them so hard they began to strip. I went beyond the cracking and creaking sounds of the plastic and I was using my body weight to turn the ratchet.
Old Aug 19, 2024 | 01:24 PM
Good! Then you know the pins are seated fully! Thanks for confirming!
Bonez
Jul 14, 2022 08:21 PM
Garyroe75
May 24, 2022 09:03 AM
MLDD
Feb 24, 2022 09:49 PM
findmyhome
May 22, 2019 03:49 PM
Lee3333
Mar 27, 2008 01:08 PM
