Ignition lock problem
Old Oct 27, 2020 | 10:30 AM
luisan's Avatar
Still chiming with key removed
Hi, I've been having this strange problem for a couple of months: I turn the engine off and remove the key from the ignition, open the door and the chime starts sounding until I close the door! Also central locking, remote door opening with fob and tire pressure indicator u/s! The car sat with a dead battery for a month until I got it replaced. Any idea? Thanks
Old Oct 27, 2020 | 11:31 AM
A couple of months or 3 years ?
You brought this same problem up 3 years ago in this thread: https://www.chevyhhr.net/forums/prob...problem-59606/
No need to start another thread about the same issue.
Old Oct 27, 2020 | 01:13 PM
This one? Good eye FMG , threads merged
Old Oct 27, 2020 | 02:04 PM
You r profile says it is a 2009 you state here it is a 2008. 2008 models have a problem with persistent memory in the RCDLR; if the battery dies the RCDLR needs to get updated firmware. You will need someone with a computer and a CANbus adapter and access to tis2web to get the new firmware.
Old Oct 27, 2020 | 03:12 PM
Either way , my question is we’re you able to get those recall repairs performed, especially the ignition switch?
Donbrew has a great point about the reflash.
Old Oct 27, 2020 | 05:25 PM
PITER88's Avatar
May I explain that. Europe don't get it, in meaning of us pcm, bcm and other stuff that communicate car - eaven tech2. In europe tech2 is used for opel's till 2017 cause from '17 it has beed sold to half french psa. Also tech2 is used for saab's. However, trust me US based cars is black magic. For example was hopeing that will fob's can be done w/o tpms ... ka boom ... not ... black magic. Then quick reading forum knowlage that tpms is part of safety and it is unable to turn it off in US in some EU brands it is possible.
Old Oct 28, 2020 | 08:17 AM
Tech 2 was retired world wide. Now you can get the software and adapters for reasonable cost and short term subscriptions to tis2web are not outrageous. The problem now, is finding somebody that knows HOW.
hawky220
Dec 29, 2020 08:24 AM
Odi
Jul 20, 2014 04:06 AM
tantrim
Mar 25, 2014 08:14 PM
Haunted_Hot_Rod
Mar 4, 2012 09:02 AM
leilani
May 3, 2011 05:01 AM
