Installing factory fog lights 2006 LS
Old Jan 3, 2023 | 10:19 AM
The posts have been moved to this new thread.
the difference between switches is the shape of the cut out.
If your aim is to avoid programming, I would just use the existing wiring and and install a high beam cutout relay and a momentary switch. As was discussed the yellow wire activates the relay.
Easier to use the existing fuse and relay if you are already willing to mess with the fuse box.
A VOM or test light would verify which wires are already connected. You have a schematic and evidently some knowledge.
in the factory setup the switch sends ground to the BCM then the BCM sends a 12V + to the relay on the yellow wire.
The simplest ,but not legal, way is to insert a relay in place of the BCM or wire the switch to voltage. To be legal you need to cut the high beams off.
fogschematic.pdf
Old Jan 18, 2023 | 07:26 PM
FallGuy2005's Avatar
I want to run independent wires to the switch. However, I do not want the fog light to be able to turn on unless the headlights are one. Where do I connect?
File Type: pdf
Old Jan 18, 2023 | 07:43 PM
If this is a 2006 tap into the low beam circuit with a relay. That would enable only when low beams are on, satisfying the law about high beams.
Look at the headlight circuit.
Low beam relay output to your switch that energizes a relay with separate supply to turn the fogs on.
Old Jan 19, 2023 | 07:31 AM
Post #5 has a schematic of the lo beam wiring
https://www.chevyhhr.net/forums/gene...em-help-59595/
Old Jan 19, 2023 | 08:33 AM
That is not for a 2006.
I would use 1, 2 or 3 in that order to activate a power relay.
Old Jan 19, 2023 | 08:37 AM
The low beam wires are the same all years, the drl are 2006 specific
Gearhead1
Aug 26, 2022 04:50 PM
titoc11
Mods - Exterior
7
Aug 19, 2013 05:53 PM
MODIFIEDmodified
"How To" Tutorial Library
Sep 9, 2011 03:16 PM
butch686
Mar 6, 2011 09:14 PM
cosmic1
Sep 1, 2010 06:56 PM
