interior lights out
huh? if you're talking about the badge mixup, that wasn't me haha.
Cajun, it's not too big of a deal, after looking at what happened, i can very easily see how that could have done it by accident. when i picked up the car from the body shop, they mentioned having some trouble getting the tail lights to work right (i have the IPCWs), and apparently what they did wrong was they missed the signal wire that runs from the top lamp to the bottom, so you have both rings light up for running lights. after removing them again, they found this, fixed it, and reinstalled. they ended up just BARELY catching the signal wires and pinching them with the little mounting cup thing for the tail lights. i'm not going to fault them too much for it, because i almost did the same thing after i fixed the pinch.
Interior lights out - check taillights
Yes, to put it simply, interior panel lights are on the fuse for the running lights and tail lights. These panel lights are the backlights for the heating and air conditioning controls, the shift indicator, window control switches, etc.
So, if you lose those lights, CHECK YOUR OUTSIDE LIGHTS!
Thanks for the discussions here.
Gsus
Jun 26, 2009 12:56 PM
