Knocking noise
Old May 23, 2019 | 08:36 PM
A gauge would be able to signal a crashed pump.
When was the last time you heard of an oil pump on a street vehicle completely failing?
The point is knowing that there is pressure in the oil system doesn't help anything except that the pump has not failed.
Look at the pump and figure out which parts might catastrophically fail.
Old May 23, 2019 | 09:27 PM
I was thinking old small block chevies.
Old May 23, 2019 | 09:40 PM
J W Davis's Avatar
Yea, like when the plastic barrel (used in seventies) would break and let the rod drop from the distributor to the pump. HA!
Old May 23, 2019 | 09:56 PM
Yep, you remember...
donbrew
Dec 26, 2014 09:00 PM
chocolatefonz
Jul 19, 2010 12:26 PM
ginginee
Feb 3, 2010 09:42 PM
Jeff®
Aug 20, 2008 07:09 PM
citigirl79
May 17, 2007 09:26 PM
