Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
A gauge would be able to signal a crashed pump.
When was the last time you heard of an oil pump on a street vehicle completely failing?
The point is knowing that there is pressure in the oil system doesn't help anything except that the pump has not failed.
Look at the pump and figure out which parts might catastrophically fail.
