Low battery on key FOB
Old Jan 31, 2013 | 07:21 PM
Old Lar's Avatar
After ~7 years of ownership, this messaged popped up on my DIC. I have two key FOBs one died years ago. I just bought a new battery and all is well. I was just surprised at seeing this message.
I looked into the other key FOB, and discovered that the bracket that holds the battery in place was broken.. But the key works, but no auto locking or door opening.
Old Feb 1, 2013 | 10:16 PM
badassbowtie's Avatar
7 years is a while... I've already replaced both of mine
Old Feb 1, 2013 | 11:44 PM
phbassnotbass's Avatar
wow 7 years
I've had both fobs replaced. Both battery holders were broken. 1 of the replacements has already failed same reason and I suspect the same with the second.
Old Feb 2, 2013 | 08:10 AM
B.Diggity's Avatar
My panic button works fine. Lock, uh kinda workd. Unlock, does not work period. i need a new fob but too expensive so I just lock it with fob n stick the key in everyday and test my horns lol.
Old Feb 2, 2013 | 09:23 AM
You probably need just a new pad. You can get a new case including the pad for around $10. You just open the case and switch the circuit board to the new one. Or get the "keyless fix" for around the same price.
Check Ebay, you can use the fob case with the 5th button marked "trunk" it just doesn't do anything, they are easier to find and I know they work from experience.
Old Feb 10, 2013 | 03:48 PM
Lonewolf_ict's Avatar
programming?
do the new key fobs need to be programmed to work? I replaced the battery in my fob a while back. the panic button works but that's it. Will not lock or un-lock.
Old Feb 11, 2013 | 06:20 PM
Yes, a NEW fob CIRCUIT BOARD needs the dealer to program, a new fob CASE or PAD does NOT.
See the previous post.
Old Feb 12, 2013 | 04:05 PM
Old Lar's Avatar
I noticed that the remote start no longer works. I rarely used it, but I'm cruising upstate NY and it is in the 30s..
Radco
Jul 9, 2017 10:02 AM
HMHHR
Jun 22, 2012 12:27 AM
Lee3333
Maintenance and Upkeep
Jul 17, 2011 09:57 PM
longhornss
Feb 27, 2009 01:15 PM
Lee3333
Feb 17, 2008 02:39 PM
