low brake fluid
Old Oct 21, 2020 | 02:06 PM
flstss's Avatar
I don't know what you mean by loose pin. On the ABS module? I bought a spare one and they both give me the same reading. This leads me to believe a ground issue. I am going to change the brake level sensor next and if that doesn't work back to chasing grounds
Old Oct 21, 2020 | 03:53 PM
What does the fluid level sensor have to do with your problem? You have not presented anything that would get near to pointing in that direction. It does not even connect to the EBCM.
Loose pin; Like a pin in the connector that got pushed back instead of into the socket.
There are 3 ABS fuses in the underhood fuse box #44, #57, #61. One of those could be the culprit.
Maybe read my posts.
fastsuv
Jun 28, 2020 10:57 AM
dino9832
Jul 10, 2019 11:19 AM
fastsuv
10
Feb 20, 2019 05:38 PM
mjsz34
Sep 6, 2013 08:55 AM
bobnj
Jun 13, 2013 05:17 PM
