Low Brake Pedal after Hub assembly change.
Old Sep 20, 2017 | 04:00 PM
  #31
Man, I had one of those, a great device for a quick setup for drum brakes, but that way back when I used to run 11 x 3 inch cop car drums on all four corners of my 67 Plymouth .
Satellite.
That might be in the bottom drawer of my tool chest. (Read in junk drawer)
Old Sep 21, 2017 | 12:06 AM
  #32
prod's Avatar
Check the front brake lines, a panic stop can over stress them and cause them to become weak and swell close to the caliper. That would cause a softer pedal.
Old Sep 23, 2017 | 08:22 AM
  #33
DrLoch's Avatar
I'm assuming you mean brake hoses
Old Sep 25, 2017 | 11:50 PM
  #34
prod's Avatar
Yup, I meant the rubber hoses going from the hard lines to the calipers.
Sometimes you can see them bulging at the end.
Old Oct 3, 2017 | 06:23 PM
  #35
Blue_SS's Avatar
or... if there was air in the HCU portion of the ABS module, it could explain it.
The electronic bleed might just need to be done again. When I used to to do low-level motorsports(different vehicle with ABS), this was not unusual. If the system is opened, air gets in, and it can go to the ABS module. 1 panic stop and it goes out into the previously good system.
I had the good fortune of regularly braking hard, so this surfaced fast... lol
It's an idea, at the least. Hope it helps.
If I bleed brakes, I always exercise the ABS. Some electronic units don't.
arttysHHR
Nov 13, 2010 11:11 PM
jcmorehead
Dec 29, 2009 06:10 PM
andoll83
Apr 1, 2009 07:14 PM
rocko54
7
Mar 8, 2009 12:24 AM
xzombiex66
Mar 28, 2007 05:44 PM
