No tail light, no radio button, no heater control light
Old Mar 7, 2018 | 09:14 AM
  #41
hollywood23113's Avatar
Yes back to normal being normal for this car when I got on here. Taillights/Running Lights/Parking Lights all the same switch and I consider to all be running lights. Post #36 says everything but the running lights/ taillights same thing. Sorry if I confused you by saying back to normal, I meant the car starts as it should, and I am back to where I started after a junk yard fusebox
Old Mar 7, 2018 | 10:22 AM
  #42
First thing is to check continuity of the white wire from the BCM to the relay, and check for signal (ground) on the same wire.
Old Mar 7, 2018 | 10:52 AM
  #43
Did the multi switch get changed out?
Old Mar 7, 2018 | 12:41 PM
  #44
Yes tried the multi switch
Old Mar 7, 2018 | 01:40 PM
  #45
That is continuity between
this on the BCM (inside fuse box)
And this on the underhood box, probably pin 85, but might be pin86, the other one should be 12V. 87 should be 12V. 30 goes to the bulbs.
Old Mar 7, 2018 | 02:15 PM
  #46
I will have my mechanic check it, I don't know how. Thanks for the clear diagrams
Old Mar 7, 2018 | 02:31 PM
  #47
Cat Man HHR's Avatar
Here's a picture of the relay pinout:
Old Mar 8, 2018 | 01:21 AM
  #48
This relay is 4 pin.
Old Mar 8, 2018 | 06:44 AM
  #49
Five pin, 87A in the middle isn’t used.
Old Mar 8, 2018 | 08:33 AM
  #50
The pictures in #45 aren't explicit enough? Gonna have to switch from Playboy to Hustler versions.
