Outside thermometer temperature
Old Jun 5, 2013 | 11:17 AM
Laco's Avatar
They seem to read high. Mine is usually about four to five degrees high.
Old Jun 5, 2013 | 01:54 PM
HHR2011dave's Avatar
GM service Bullatin
Was wondering about outside ambient temperature slow to update on
rising temps outside and found this . Read carefully !! http://ww.w.autoelectricpro.com/purc...000/110283.pdf
Old Jun 5, 2013 | 07:15 PM
stephofthedead's Avatar
By high I mean the cluster displays 52°C (~125°F) when it is 25°C (~77°F) outside, the sensor is definitely bad.
Old Jun 8, 2013 | 12:55 PM
I have noticed on my 2011, which has the probe mounted in the lower grille opening, that when the cooling fan is on the ambient temp goes up several degrees. Presumably because the fan is blowing heated air on it.
Old Jun 8, 2013 | 09:06 PM
I still haven't changed the sensor and today I thought it came back to normal again. When I started the car to come back home this evening I had this: 60°C (or 140°F). I think this is the max temp for the sensor because the number didn't change during the whole hour and a half long trip.
Old Jun 8, 2013 | 09:24 PM
Yep, probably "open circuit" reading. The sensor is a diode, when they fail they go open (or closed depending on your point of view) which gives you the reading of the circuit instead of the diode. If you were to put a VOM on the leads you would probably get .060 volts.
Restlessone
Jan 1, 2015 06:35 PM
TEKNOnaut
Jul 1, 2012 07:08 PM
Ponyman1
Sep 6, 2009 06:12 PM
budzone
Jan 23, 2009 09:50 PM
TxSkyPilot
Aug 17, 2007 05:30 PM
