P0014 Code 2011 HHR
Old Jun 22, 2021 | 06:56 PM
There , you inspected it, now you’re confident it’s not the timing chain that’s the problem!
now let us know after you swap out those VVT solenoids
Old Jun 24, 2021 | 07:01 PM
CDawg's Avatar
Final Update...
Replaced the solenoids with AC/Delco. The ones I got from NAPA were duds... The exhaust was the one giving the erratic readings and I assume that caused the code. All connectors checked out ok.
Small leak around the valve cover so replaced the gasket. Also, found a little carbon on the throttle body so a little cleaning was in order there.
No slack in the timing chain.
Good to go.
Thanks to all for your wisdom!
Old Jun 24, 2021 | 07:45 PM
Awesome, enjoy the ride! Another example for future readers get the right parts the first time! Save you the time and aggravation!
gag
Apr 12, 2024 07:13 AM
ecpff
Aug 21, 2016 04:13 AM
fastsuv
Jul 1, 2014 11:15 AM
Turboo2u
Sep 15, 2013 08:22 PM
chefan
Feb 9, 2013 07:35 PM
