P0106 Code
Old Jul 1, 2023 | 09:58 AM
Discount code is in effect until July 14, 2023
https://www.chevyhhr.net/forums/loun...ockauto-61707/
Old Jul 1, 2023 | 01:32 PM
PulpFriction's Avatar
Originally Posted by Ritasmobile
Checked the recall status. All recalls done; most pertain to the ignition key. Going to order a Bosch MAP sensor from Rockauto today, none of my local auto parts stores have a name brand in stock. Will post the results of timing chain inspection Monday or Tuesday. Thanks again to everyone who has posted suggestions. We'll get her fixed soon.
If you gripe enough, sometimes GM will re-do a recall if it fails again. I seem to recall a TSB for power steering motor that basically says if a car is presented with a ps bad motor, fix it. No mention of checking to see if it's been done before. Could be wrong.
PSA, any GM dealer can address such issues, and you won't get the same experience at every dealer.
Old Jul 2, 2023 | 09:05 AM
Ritasmobile's Avatar
Thanks Blue; saw the code just in time before ordering. A dollar saved is a dollar earned.
Old Jul 2, 2023 | 09:36 PM
I guess I went invisible again.
P0106 will NOT disable the car.
Old Jul 2, 2023 | 10:38 PM
I see you donbrew. Rita, please review post #16. If the problem is indeed the timing chain, continued cranking(and operation) could destroy the engine.
Old Jul 3, 2023 | 05:00 PM
  #26
...I'd be worried about timing chains, not that I think that's it, just that I think it needs to be eliminated first.
Originally Posted by donbrew
Remove the bolts that hold the valve cover, remove valve cover, look at the chain between the sprockets; any slack is bad, there should be a bit of plastic attached to the metal guide above the chain bad if gone.
I gotta cut this out. I'm afraid I'll begin taking perverse pleasure in the misfortunes of people who ignore good advice.
LON
Mar 28, 2022 05:33 PM
bd20
Jul 9, 2013 07:44 PM
RETRO-RED-EXPRESS
Feb 8, 2011 10:13 PM
Lonewolf_ict
Jan 12, 2011 04:39 AM
Geoff
Jan 21, 2010 05:23 AM
