P0172 code after replacing VVT solenoids and Mass Airflow Sensor
Old May 26, 2026 | 04:03 PM
Did you order the stronger front guide from ZZP?
https://zzperformance.com/products/z...ng-chain-guide
Old May 26, 2026 | 04:09 PM
FozzyOsbourne's Avatar
Yeah it's the timing chain. It's bad enough he called me down to look at it so I wouldn't have to take his word for it.
One of the guides apparently broke off and got chewed up.
After that, the chain was free to saw into one of the bolts.
"It looks like glitter in there."
The chain was soooo loose, he's not sure how
He's afraid that even after cleaning it up as much as possible replacing the oil pump, water pump, and all of the timing components, he couldn't be sure they got everything, so it might foul up all over again 100 miles later.
He's going to call around and get some prices on replacement engines.
I might just have to sell it for scrap.
Old May 26, 2026 | 05:18 PM
If you get a used engine use the timing chain kit and water pump on it. It is a lot easier to change on the floor than in the car.
Figure about $1,000 labor and $800 for the engine (guestimate only).
Old May 26, 2026 | 05:21 PM
Yeah, he said he would definitely use those parts, because they always put on a new timing set with a replacement engine.
I'll keep you posted.
Old May 26, 2026 | 05:26 PM
I forgot to include the picture
Old May 27, 2026 | 07:18 AM
  #26
That’s why I recommended the ZZP front guide!
Tweetip10
2.2L Performance Tech
49
Dec 6, 2024 08:30 PM
mobilebyrd
Mar 24, 2020 06:44 PM
BDR1973
Aug 8, 2016 08:40 AM
voigtsga
Aug 22, 2014 05:29 PM
Jim W
Oct 2, 2012 09:42 PM
