Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Donbrew,
From the pictures it looks like a nut was added on top to secure to ground wire.
I do agree with you in that this "patch" DOES NOT fix the issue, it just hides it.
AllenP,
I'm glad you found the problem.
You now know the issue is a ground wire,so,
If you're going to fix an issue, do it right.
I just finished getting a new wire put, with ring crimp ends.
I think I'll leave it like this for a while until I have more time to look at the ground wire issue.
I'll take extra care when jumpstart ing, if the need arises.
But if I did have to check, where should I start looking for that ground wire?
