Radio issues
Old Dec 30, 2024 | 02:08 PM
TheShadowMan's Avatar
Radio issues
I have a 2009 Chevy HHR LS (no pioneer sub system)
MY radio is only playing audio out the two tiny speakers on the pillars, I am trying to find the amp. (checked in the rear quarter not one there.) the fuse box states I have an amp but can't seem to find it or figure out the issue why none of the other speakers produce any sound.
Old Dec 30, 2024 | 02:32 PM
The other 4 speakers are burnt out, it happens mostly to base radio systems. Check Crutchfield web site for sizes of speakers the fit your HHR. Then you can purchase what ever brand and price range you want.
Old Dec 30, 2024 | 04:29 PM
If you don't have Pioneer you don't have an amp.
What language does your fuse box speak?
Old Dec 30, 2024 | 04:35 PM
Yeah that's what I thought too but clearly it states on the fuse box amp and has a 20a fuse inside the slot.
That's why I am confused on this issue
Old Dec 31, 2024 | 10:53 AM
PulpFriction's Avatar
There must be dozens of these threads here. A gazillion radios have been pointless replaced because owners just couldn’t believe ALL the door speakers would fail.
Just replace all the POS OEM door speakers with 6.5” aftermarkets. Even cheapies will be an improvement. (I like Kickers.) High wattage not needed, the radio doesn’t have much power. Efficiency is your friend. Do not use the original connectors. They’ll be corroded. If you want louder, add an amp and run bigger speaker wires.
Make it easy on yourself and get these adaptors:
Rich the confused
Aug 10, 2022 06:08 PM
Radco
Jan 12, 2022 12:07 PM
Dolfan594
Feb 18, 2021 08:58 PM
Luke Hitson
Aug 12, 2018 01:44 PM
Lee3333
Oct 21, 2006 12:17 PM
