radio problem
Old Jan 28, 2011 | 12:14 PM
Sno White's Avatar
Originally Posted by blu ss
i don't think it is an antenna problem because when the radio makes static or no noise at all and you turn the volume knob , it puts the volume graphic on the radio screen and no matter which way you turn the knob or how many times you turn the volume knob it does not get louder or quieter. and the volume graphic does not change by adding or removing those little sound blocks to the volume graphic.
I agree. It is a bad radio.
Old Jan 28, 2011 | 12:19 PM
Sno White's Avatar
Originally Posted by Kevin09HHRhappy
Does your FSM show me where around the dash/console, that I can tap into feeds from the transmission position switch. I'm looking for a signal when the vehicle is in PARK and also when its in REVERSE.
I have only researched things applicable to the BCM - so no, I would not know. If however, you would detail what you are actually trying to do you may spike somebody's interest that might already have your answer OR another way to attack what you are trying to do. Might want to start your own thread, we have taken enough of the OP thread.
Rikki Sixx
Sep 6, 2015 12:56 PM
mdharris55
Jul 15, 2014 11:06 AM
Dingj003
Dec 3, 2012 10:45 AM
FORTIZ
Feb 15, 2009 11:08 PM
chris082676
May 22, 2006 05:51 PM
