Remote Control Not Working....
Old 09-07-2010, 12:04 PM
luisan's Avatar
No,I changed the battery in the remote and it (they)still don't work and I've also noticed that the little spot light's not working.
luisan is offline
Old 09-07-2010, 12:12 PM
luisan's Avatar
Originally Posted by donbrew
I hope this was an insurance replacement. The RCDLR (remote control door lock receiver) is not working. It controls the door locks and the TPMS (tire pressure monitoring system). It lives under the bump on the headliner next to the rearview mirror. Sounds like Mr. Goodwrench needs to be involved, if it was an insurance claim they should pay.
Yes,I would agree with you because the remote AND the TPMS are not working
along with the little spot light.Is there any test I should do before I buy the replacement RCDLR?Note that prior to the door change everything was in working order.Thank you!
luisan is offline
Old 09-07-2010, 12:16 PM
If it worked before the door replacement I would suspect electrical connector or bad ground where the door harness plugs in.
Greybeard999 is offline
Old 09-07-2010, 05:26 PM
If you paid someone to replace the door, it is their problem. I do not think up and replacing RCDLR is a good way to go about it. OK, so the spot light does not work; it is tied to the dashboard lites, which come on automatically when the headlites/parking lites are on (NOT when DRLs are on), do you have headlites? This is sounding like somebody messed around were no one should however check the electrical connectors at the door, could be bad connections or shorts either in the connectors or inside the door switches. Do the locks, windows and mirror work?
donbrew is offline
Old 09-07-2010, 05:34 PM
goetylsd's Avatar
Originally Posted by RacinRex
I Think I would go ahead and try the battery. I have had the remotes mess up like that and all it needed was a battery for a few bucks. BTW am I reading right you have a 2007 with 117,000 miles? good luck.
Yes, I have 117,000 miles on my 2007 HHR. It has proven to be very reliable even at such high miles. No major problems of any sort yet; I am very satisfied with my HHR and have a lot of faith in it.
goetylsd is offline
Old 01-04-2011, 08:04 AM
  #26
johnmilam's Avatar
I'm finding that it's not the remote key fob, but rather the built in antenna. It works intermittently, and after using the new (never used) spare key fob, it does the same thing.
Does anyone have a solution?
Thanks,
johnmilam is offline
Old 01-14-2011, 09:59 PM
  #27
vinmans brew's Avatar
John, I am finding the same thing. Both my remotes do not work are barely work. One did have a bad solder joint but I fixed that and it was better for a bit but now the remotes work about 1 in 20 tries. New batteries too.
Also, the alarm arms itself when locking with the electric lock button on the door, not just the remote.
And to clarify, my remotes do not lock or unlock.
vinmans brew is offline
Old 08-21-2015, 12:00 AM
  #28
songman1505's Avatar
And, yes if you lock with the remote then open with key anti-theft goes into effect. It's in the manual
Interestingly enough I have the same problem with the key fob not always working but found if you use the key then count 1-1000 up to five before opening the door 90% of the time the alarm won't go off.
songman1505 is offline
ImNewHere
05-27-2014 11:05 PM
tntwolt
06-02-2013 10:30 AM
voigtsga
04-25-2013 09:24 PM
MikeloftySF
04-19-2011 11:00 PM
xpeppyx
06-22-2010 07:46 AM
Quick Reply: Remote Control Not Working....
