Remote engine start ?!
Old Jul 30, 2017 | 03:03 PM
The hood switch is 2 circuits to ground. The RCDLR (Remote Control Door Lock Receiver) is responsible for receiving the radio signal from the fob. The BCM is responsible for remote start.
The wires under the hood are visible, they are connected to the latch as in the picture, on top of the A/C condenser.
Where does the pink wire go?
The RCDLR is under the interior trim panel behind the driver side raer passenger seat. If the door locks work it is working.
I doubt it has anything to do with the LPG installation.
Here is a list of conditions fo the RVS to work, add the Hazard lights must be off.
Old Jul 31, 2017 | 04:43 AM
M3ndoR's Avatar
RVS can be switched off manualy ? first point of the list. Or if i have the AB3 i have it always enabled ?
It seems that all points of the list i can check that are propper, but the engine still wont start
Old Jul 31, 2017 | 08:05 AM
You still have engine codes, or the hood latch sensor is causing a problem, or the remote is disabled in the DIC
Old Jul 31, 2017 | 08:15 AM
M3ndoR's Avatar
i dont have any error cause they ware erased, as i typed hood ajar is not showing on dashboard anymore
Old Jul 31, 2017 | 08:29 AM
It can be disabled in the DIC personalization menu, or by turning the hazard lights on.
No errors in memory? The light does not have to be on.
Old Jul 31, 2017 | 09:11 AM
You may have cleared them but running the car can keep them lurking until the run cycles pop up the code again
Old Jul 31, 2017 | 09:13 AM
M3ndoR's Avatar
got it back to the computer. i have VGATE OBDII whats the best program for it ? Can You guys suggest something for free ? PC + ANDROID
Old Jul 31, 2017 | 09:19 AM
Torque app for android is free.
Old Jul 31, 2017 | 09:20 AM
M3ndoR's Avatar
thanks will download, and try it
Torque and ScanMaster ELM, for android are pretty good in the free versions. I know in the US Torque is available from the Play Store.
