Replaced hub - now car won't move
Front wheel bearing hub assembly replacement, it was rusted to drive shaft, used heat, hammer and gear puller to remove. Reassembled, car want move in any gear. Would this be,a drive shaft assembly or transmission problem? Any suggestions on places to start? Thanks, hhr ss kazoo 5spd.
I suggest tracking your steps back , could it be a bolt too long?
Could it be a brake rotor, you know how some use a screw driver to hold the rotor whilst they torque the axle nut.
Just suggestions, without seeing the car
So just for my own info, would proper procedure be to torque the axle nut wither with the wheel on the ground or at least have the opposite wheel on the ground? Ive never had to replace a Hub/Axle.... Yet
PanamaJack
Jul 11, 2016 10:14 AM
Goldie6175
Apr 25, 2014 06:37 PM
