Seat belt sensor
Old Nov 27, 2020 | 07:15 AM
Then follow the wire back to where it plugs in and unplug it.
Allen P's Avatar
It's wired under the carpet, Im hoping it's not too long
Old Nov 27, 2020 | 08:31 AM
fastsuv's Avatar
According to the service manual for my 2006, there looks to be a connector under the rug close to the belt:
Steve
Old Nov 27, 2020 | 08:59 AM
If it is locked it must have triggered. If it did trigger you must replace it.
The wires terminate at the airbag "brain", behind the gear selector.
Maybe if you explained what you are trying to accomplish we could help. I am confused at this time.
Old Nov 27, 2020 | 09:09 AM
Allen P's Avatar
I'm trying to get it replaced, but it looks like fastsuv has answered my question. I'll make sure to check under the rug for a connector like the one in his picture.
Old Nov 27, 2020 | 10:55 AM
Allen P's Avatar
Steve
Success!!
Thank you very much everyone.
Old Nov 27, 2020 | 11:35 AM
Sometimes, when a seatbelt is locked, using the adjustment button on the pillar to adjust down, will free it up.
Old Nov 27, 2020 | 11:41 AM
Good point, RJ . Please future readers , try that first.
Old Nov 28, 2020 | 01:33 PM
geg's Avatar
geg
once my belt got stuck too...
There is a blocker inside the seat belt mechanism - this is an ordinary ball. My ball got wet and stopped rolling correctly inside the mechanism.
I detached the entire knot, unwound the strap all the way and dried it with a hair dryer. I was drying the textile belt and mechanism.
The belt is detached with a regular wrench. It is fixed at 2 points: one end near the seat (this is your photo); the second is the mechanism itself (a coil with a lock on a steel bracket) screwed to the body.
See the diagram above. Turn off the battery first, this is a must because the seat belt is equipped with an igniter. Then remove the casings, then disconnect the wire connector (where that is the plug), then unscrew the nuts, extract part and look for the cause of the problem. Be careful with the yellow connector - this bastard is gentle and very expensive. Look for the video on the Internet, if you find it, it will be easier to work with.
BUT ... Before removing the belt, move the upper belt adjuster. This is such a bar on the side trim of the B-pillar at the top. You can easily recognize her by the gap from which the seat belt sticks out. Sometimes it is enough to push it up / down to unlock the belt.
Old Nov 28, 2020 | 01:35 PM
geg's Avatar
geg
sorry,
did not read the branch to the end and wrote what was already said without me
rywegh
Jan 22, 2013 07:56 PM
1900colt
May 28, 2012 08:17 PM
brownster
Jan 11, 2011 09:41 PM
jerSSey HHR
Aug 3, 2008 04:45 PM
Old_Chevy_SS_Man
Jan 11, 2008 03:01 PM
