Severe coolant leak all of the sudden
Old Nov 9, 2020 | 09:26 AM
Old Nov 9, 2020 | 09:51 AM
slonny's Avatar
Now, I am even more confused when I look at this picture. Is there a guide for its removal?
Old Nov 9, 2020 | 12:43 PM
slonny's Avatar
Found this video of the whole process:
At 9:00 the guy actually shows where this housing is.
Old Nov 9, 2020 | 01:15 PM
Originally Posted by slonny
Got it. Is this it?
that is the thermostat housing, and the block under it needs to be removed, should be 3 bolts
Old Nov 9, 2020 | 02:03 PM
Why is this thread in the GM Recall Campaign section ?
FYI. This thread started out asking where the leak could be coming from. The water pump was suggested. Never did see anything posted where it was confirmed that's what is leaking.
I hope you're not just replacing the water pump hoping that's the problem.
( maybe it's not the water pump. The O ring on the coolant tube or the tube itself ? )
Old Nov 9, 2020 | 02:49 PM
slonny's Avatar
Looks like water pump. It is definitely not leaking from the tube. I checked out the other side.
Old Nov 9, 2020 | 03:35 PM
Moved, thanks FMG!
Old Nov 9, 2020 | 05:20 PM
I guess you could look at the link I provided to the water pump replacement how-to. It skims past the tube and housing removal because it is intuitive. I.E.: remove the bolts holding it. The only "magic" involved is the gear holder the rest is "remove & replace".
What is confusing about the picture? My intent was to show the transfer tube from the t-stat housing to the pump. It has O-rings on the ends; I suspect they are your leak.
RJ_RS_SS_350
Oct 3, 2020 07:47 AM
Frank Larrabee
May 10, 2018 08:04 AM
hhrmomma
Dec 18, 2016 09:31 AM
SamuelJ
Nov 16, 2015 03:45 PM
B.Diggity
30
Nov 7, 2012 11:16 AM
