shifter stuck/sticks
Old Dec 30, 2017 | 07:40 PM
  #41
Ah, yes the shifter is under an extended warranty!
Old Aug 24, 2024 | 10:27 PM
  #42
7eus's Avatar
Got stuck in park today, I was able to put it in drive using the little access hole in the driver side of the center console accessed by removing the big “U” shaped panel.
When I got home, turned out to be the brake actuator. I confirmed this by the lack of brake lights and 12 volts at the connector. The actuator was very easy to pry open and clean with QD. Watch out for the switch spring shooting out when you remove the lid. Brake lights and shifting is back to normal now.
edit: Yes I did try spraying WD-40 into the actuator before all of this
Old Aug 25, 2024 | 07:23 AM
  #43
You got it fixed, that’s the main thing!
Old Dec 13, 2024 | 06:10 PM
  #44
vettie101's Avatar
Originally Posted by northrivergeek
I too have this problem this am .. I have yet to have all the other recalls done, hopefully this issue is covered by drive train warranty .. its 24 outside this am .. I'm assuming the cold has something to do with it .. just hear click click click .. sounds like a combo of the ignition clicking and the shifter.. and after reading several posts .. could be the brake pedal safety switch, or the shifter .. or possibly in the steering column.
Ive already had bearings replaced and the axle snapped under warranty .. now this .. .. hhr got to get rid of this POS car.. before something else falls off
I agree 100% with you. I have a 2010 Chevy HHR and everything in the world keeps going wrong with this piece of s*** I hate this car
Old Dec 14, 2024 | 08:34 AM
  #45
PulpFriction's Avatar
Originally Posted by vettie101
I … I have a 2010 Chevy HHR and everything in the world keeps going wrong with this piece of s*** …
Weird. And only 15 years old. How many miles?
Old Dec 14, 2024 | 08:57 AM
  #46
My 2LT 2011, over 200,000 miles, I’ve replaced things, but it’s still running strong
Old Dec 14, 2024 | 09:30 AM
  #47
desertrat's Avatar
I had the same sticking shifter, but could hear the solenoids clicking when I pumped the brakes. I removed the chrome trim around the shifter and used WD-40 (with the red straw extension) and hosed the area where the shifter pin is, see the picture at the beginning of this thread. I worked the shifter back and forth a few times and now it works like new. Total time invested- 5 minutes.
Old Dec 14, 2024 | 10:34 AM
  #48
I did the same thing to my 2011.
Old Dec 15, 2024 | 08:40 AM
  #49
Originally Posted by desertrat
… I removed the chrome trim around the shifter and used WD-40 (with the red straw extension) and hosed the area where the shifter pin is, … I worked the shifter back and forth a few times and now it works like new.
Good move. I might be inclined to follow up with some lock lube. WD-40 likes to dry up and get a bit sticky with time.
Old Dec 15, 2024 | 02:21 PM
  #50
The WD40 cleans the sticky stuff off; it is the factory applied grease that solidifies.
