Steering wheel rocks to and fro
Old Feb 10, 2017 | 10:06 AM
  #41
I'm with Don. Not sure why the alignment guys left your toe "off" as much as they did.
Here's the alignment done on mine after my lowering springs were installed.
(SS FE5 does have some different specs )
Old Feb 10, 2017 | 11:06 AM
  #42
JazzDad's Avatar
Originally Posted by donbrew
B. Worn out hub/bearings will cause odd wear, usually either inside wear and/or cupping, much like camber
I am wondering why the tech bothered changing the toe, if he was going to leave it "not perfect". As far as I can see there is no improvement. It started out within limits ended up still within limits, but still not optimum. In fact, it was better before than after.
Typically, can you feel a bad bearing by man-handling it? I have no play in the front end that I can feel. I've had hub bearings go bad over the years (1 on this vehicle, some on others) and the only symptom was the noise it made.
I don't want to put new tires on just to have them ruined.
Old Feb 10, 2017 | 01:53 PM
  #43
The thing is, if you can feel it it is way too late. The end play tolerance is .015 inch.
Cupping is usually a result of bad bearings, sometimes worn out ball joints, etc.
Old Feb 11, 2017 | 10:03 AM
  #44
And sometimes worn out rear LCA bushings, and combinations of these parts!
Old Feb 20, 2017 | 11:06 AM
  #45
JazzDad's Avatar
The dealer stated I was good-to-go for new tires, so I put a new set on. He said if anything was wrong with the front end, they would have told me (read: sold me some additional service). Getting that delaminated tire off made a huge difference. I guess I'll just have to watch for unusual tire wear.
mdighe
Jul 8, 2008 08:58 PM
Desert Coyote
Dec 18, 2007 04:38 PM
Nor-Cal HHR Club
Oct 23, 2007 06:10 PM
Goose
Oct 22, 2007 05:10 PM
06Daytona
War Stories
16
Jul 24, 2007 10:59 PM
