Still dinging
Old Feb 2, 2020 | 12:47 PM
  #41
bailbud's Avatar
You said the key does not seem to be as snug as it should be.
If that's so, then I would think you should replace the key cylinder instead of trying to fix the old one.
Old Feb 6, 2020 | 09:12 PM
  #42
guppy's Avatar
So what switch makes the HHR ding. Is it the black ring, I know this is part of the RFID that reads the key, but maybe it detects the key prescence as well? Or is it the white thing?
eBay
Old Feb 6, 2020 | 09:58 PM
  #43
guppy
Not exactly sure. Never had one apart to look. But, my guess is the green and yellow wires go to a sensor switch ?
Old Feb 6, 2020 | 10:12 PM
  #44
According to the wiring diagram; the white wire from the SWITCH is labelled "key in sensor" but it goes to the run/crank voltage.
Old Feb 7, 2020 | 07:51 AM
  #45
Yeah Don, that does seem to be the wire from the ignition switch to the crank relay. I was thinking the green and yellow in the picture were the wires that carried the "key in" signal from the key cylinder to the ignition switch.
Then I looked up this diagram and got more confused because it only showed the tan/brown wires. Oh well.............
Old Feb 7, 2020 | 08:53 AM
  #46
I'm getting a headache trying to decipher the wiring. The yellow is there next to the white.
Old Feb 16, 2020 | 06:51 PM
  #47
bailbud's Avatar
Was looking at the print out from the dealership and the recall was done within a month of the recall so I'm trying to get in touch with gm Canada to see if it was done with old parts, hoping to talk with a actual person tomorrow as I finally have a day off
Old Feb 16, 2020 | 07:01 PM
  #48
It’s Family Day , they might be closed.
Old Feb 16, 2020 | 07:23 PM
  #49
bailbud's Avatar
do they have that on the east coast or Ontario, Quebec wherever gm headquarters are?
Old Feb 16, 2020 | 09:07 PM
  #50
We have it here in Ontario
