Synthetic over Conventional Oil????
Old Aug 27, 2009 | 09:00 PM
  #31
Burntbeef's Avatar
Originally Posted by lvhhrpanel
The DIC does not measure oil condition. The computer monitors your driving habits to determine when to change oil (speed, rpm, temperature etc.)
ummm.... that's the same thing
Old Aug 27, 2009 | 09:48 PM
  #32
urbexHHR's Avatar
No, it's assuming when you should change it. It's not actually taking a sample of oil and analyzing it.
Old Aug 28, 2009 | 05:32 PM
  #33
Burntbeef's Avatar
I don't think anybody thought it was taking a sample of oil...
It determines the oil condition based on how the engine is ran and shows the oil's "life" as a percentage. If it was directly meant to say when to change the oil it would be either words or maybe a number scale, not a diminishing percentage.
Old Aug 28, 2009 | 07:43 PM
  #34
Chief Perry's Avatar
Well with only 2,600 miles on my "Blue Hearse", I'll start to think about an oil and filter change at about 5k.
Old Aug 28, 2009 | 08:00 PM
  #35
Jeda13's Avatar
I get mine (08 SS) down to @ 30% (4500 miles) and change it myself. I drive the car hard, and love it. Mobil 1 Synth.
Jim
Old Aug 28, 2009 | 10:30 PM
  #36
Jim
Jim-
I use Mobil 1 Syn in everything, vehicles, bikes & including my riding mower..
Peace of mind...
Billy
Old Sep 4, 2009 | 12:42 PM
  #37
briand's Avatar
I have used Mobil 1 synthetic oil for a very long time. One of the stipulations of me buying my 2006 HHR was the dealership put in mobil 1.
I don't normally follow the oil life reading in the DIC. I stick to the every 6 months or 6000 miles rule. And I always change the filter.
Old Sep 5, 2009 | 09:30 AM
  #38
nortsr's Avatar
I just found a $15.00 rebate on Pennzoil synthetic at the Pennzoil.com website. Good until November 30th, 2009. Website even gives you the closest Pennzoil oil change facilities. Hope this helps someone looking for an oil change by then.
Old Sep 15, 2009 | 05:57 PM
  #39
Zagohhr's Avatar
Hello. I tried with Royal Purple. The engine feels smoother and quieter.
Old Sep 23, 2009 | 11:44 PM
  #40
Hib Halverson's Avatar
As is the case in many GM forums there's confusion about the Oil Life Moniter system.
It uses only two pieces of data:
1) Number of crankshaft revolutions since the last reset.
2) Engine oil temperature history since the last reset.
Given the engine using an oil the same as or similar to what's factory fill, the system is very accurate as to oil condition. The only duty cycle the OLM cannot address is operation in high-dust environments. In that case, ignore the OLM light and change the oil and oil filter every 3000 miles...along with your air filter.
As for what to do if you run a higher-quality oil such as a premium, ester-based synthetic? Obviously, the OLM's software will be inaccurate with a higher-quality oil.
My testing, using spectrographic oil analysis seems to show that changing the oil at 150% oil life seems to be a good starting point for a synthetic oil, although, I'm running test right now where we'll run Red Line 10W30 to 200%...that's 50% and a filter change, 0% a filter change and reset, 50% a filter change then, 0% (the second time) an oil and filter change.
DO NOT try this with a 5W30 petroleum-based oil.
