Temperature issue.
Old May 6, 2013 | 08:39 PM
bj dix's Avatar
Temperature issue.
Hi to everyone. I am new to this site and I have a question about my 2006 with a 2.2 engine. About 2 weeks ago without notice, my temperature gauge started to fluctuate and the temperature reading got up to 230+. I had the thermostat replaced because I've heard that usually is the problem. I still have the same issue with the new one in and I have not seen 1 check engine light the whole time. The car drives like nothing is wrong but I don't want to cause any damage to the engine. There are no leaks anywhere and I haven't smelled any coolant at any point. Could this be the result of a bad sensor or a computer problem that doesn't show a check engine light? Any help and info will be appreciated. Thanks to everyone in advance.
Old May 6, 2013 | 08:52 PM
badassbowtie's Avatar
Check the coolant level first....if it was doing the same thing as before the thermostat, then your waterpump may be having issues
Old May 6, 2013 | 09:09 PM
bj dix's Avatar
Thanks for the input. I had the radiator topped off and will take it to a shop to see if it's the water pump in question. Thanks again.
Old May 6, 2013 | 10:25 PM
Also check to see if the radiator cooling fan is functioning.
Old May 7, 2013 | 10:38 AM
One thing to note: if the temp gets to 230F the computer is supposed to go into limp home mode, you would notice a severe lack of power.
Sounds mostly like the fan switch to me.
Old May 7, 2013 | 09:00 PM
I can definitely understand why you would want to get this issue looked at. If you private message me your name, address, phone number, vehicle identification number, and current mileage I can do some research on your concern and see what options you have available.
Jessica L.
Chevrolet Customer Care
Jersey Classic
Apr 27, 2019 04:28 PM
gio89kid
Maintenance and Upkeep
25
Mar 15, 2015 12:15 PM
sammyrye
Mar 1, 2015 01:07 AM
Restlessone
Jan 1, 2015 06:35 PM
budzone
Jan 23, 2009 09:50 PM
