Thermostat stuck open (I think)
Old May 6, 2017 | 11:15 AM
Lovemy9-32.0T's Avatar
As long as your thermostat has a rubber seal that came with it, It shouldn't need any other sealant. Adding other sealant can actually make the situation worse. Just place the rubber seal on the housing and tighten the screws down evenly and slowly and it should all be good.
Old May 6, 2017 | 11:23 AM
kuglerm212's Avatar
Thank You so much for the quick response, I thought so but would rather ask first
Old May 6, 2017 | 11:49 AM
I've never coated the threads on the retainer bolts or used sealant on the thermostat housing, no leaks !
Don't forget to park your HHR nose high and let any air burp out the filler cap!
Old May 6, 2017 | 12:00 PM
kuglerm212's Avatar
Thank you. I have the front end up on ramps
SwaintaN
Mar 4, 2018 04:22 AM
Wheatgerm
2.0L Performance Tech
75
Aug 2, 2015 01:23 PM
Robert Jennings
Feb 13, 2015 07:28 PM
P0757
Drivetrain (Excluding Engine)
Jan 23, 2015 07:39 AM
JT's HHR
Jun 29, 2007 03:59 PM
