Timing chain tensioner
Old Mar 4, 2021 | 07:32 AM
largojuan53's Avatar
Is replacing the tensioner bolt as easy as pulling the old one out, and threading the new one in? Or is there some special step I should be aware of. 2010 panel 130k miles.
Old Mar 4, 2021 | 07:47 AM
You might have to remove the valve cover to release the spring in the tensioner. If your engine is making noise, it’s better to change the timing and balance shaft chains.
Old Mar 4, 2021 | 09:10 AM
Thanks
Is that true for the new style bolt. I thought that it didn't need to be unloaded in the block.
Old Mar 4, 2021 | 09:38 AM
I experienced a problem with the new style not releasing and that caused problems, so , I had to replace my timing chain. As I said, you might have to activate it. Maybe not.
Old Mar 4, 2021 | 10:30 AM
I wish we would stop calling them old style/new style. There are VVT and non-VVT styles. The VVT style works in non-VVT. In a 2010 you already have the "new" style.
Why do you want to replace it? If it is extended as far as it can you need a new timing chain.
68Chrgr
Maintenance and Upkeep
25
Oct 4, 2025 07:33 AM
will1528
Feb 26, 2022 02:42 PM
reelescape
Jun 3, 2014 05:46 PM
fastsuv
Apr 4, 2014 05:58 PM
PaperChaseHHR
7
Mar 17, 2014 09:46 PM
