Tpm
I hate to admit this, but I knew about that. When the LR never lit up, I just figured the back ones dont do it, just the front ones. LOL. I am eat up with the dumbass on this project.
So I decided I would try something different. I am going "counter Clockwise" (LF, LR, RR, RF). I do this and it goes smoothly on the first 3 wheels, the last wheel RF does not chirp, so now I am without a doubt that this is my problem TPMS. Here is another question, since the RF did not take, I now have dashes next to "all" wheels in the DIC screen. Is this normal, I would have thought that the other three would at least show up with their pressures.
That sequence above is the one from my owners manual (2010). I've done it a couple times and remember it being very sensitive to time and pressure release. Had to restart the procedure several times to get it right.
Fwiw. I don't relearn mine anymore. Just rotate the tires and let it be. If I ever was to get a low pressure warning, I'll just check all the tires.
Hmmmm. Not sure how you're even able to do that. The relearn procedure goes LF, RF, RR, LR. Once you set the 1st one, it should light up the turn signal light on the RF to "tell" you that one is next. If you're going counter CW (how, I don't know) it seems it would have the positions out of sequence IF you were able to complete it.
I was planning to put new sensors & new tires on in the spring. I may still do that. Unless it's gonna cause me un-wanted Re-learn issues. ,
Just an update. I have been too busy to follow up on replacing the tpm. I am down in Texas where the temp swings have been drastic from day to day lately. On the cold days (Mid 40's and down) the tpm light comes on. On the warmer days the tpms reads fine. just an FYI. I still intend to change the tpms sensor when I get a chance. The tpms light drives me crazy.
