tpms wont sync
Old Nov 26, 2012 | 10:28 AM
If it was me I would try this first:
Take the old rims/tires out to the car and lean them up to the new mounted ones on the car, at the correct corners( hope you marked them)
See if the TPMS will now give you a reading. If yes, then your attempt at syncronizing the new tires did not work because its still reading the old ones. If you get no reading still, then I would say take it to the dealer.
Don't just ask them to reset it with their scanner. Ask them to show you how to do it with the remote. If it won't work with the remote for them, they should do it for free with the scanner as a "good will" thing.
Old Nov 26, 2012 | 12:06 PM
skyline26's Avatar
Just got back from the dealership and they told me since they are the rubber ones and not the original metal ones I had the car can't "learn" them. They said the car can only sync with the one it knows (metal) ..I find that ridiculous considering that the HHR came with both options
Old Nov 26, 2012 | 06:14 PM
skyline26's Avatar
haha $375 for sensors and bolts to attach. Parts alone! Not even including install wooooow no thanks ill just live with the yellow light on dash
Old Nov 26, 2012 | 08:44 PM
The important part is the part on the inside of the tire. Will the sender on the metal stems fit the rubber stems? I don't know what else.
Old Nov 26, 2012 | 08:47 PM
skyline26's Avatar
not sure..all i know is that there are 2 different types, your car is programmed with either #1 or #2 and you must stick with that one. Not worth it imo
Old Nov 29, 2012 | 08:53 PM
skyline26's Avatar
anyone have the part number of the oem tpms? the 'metal' one? Im looking on gmpartsdirect and they only list one style, and it looks like the black all plastic/rubber one which doesnt work on my HHR
Old Nov 30, 2012 | 12:39 AM
Omnigear's Avatar
crateenginedepot
Old Nov 30, 2012 | 08:04 AM
Putter's Avatar
Your winter tires have the wrong sensors. I had the same issue. I even got ones for a GM vehicle. There are (at least) two different types that GM uses. I think I remember that the difference is the signal frequency.
For instance, ones from a Silverado/Suburban are different than the ones used in HHR/Cobalt.
Old Nov 30, 2012 | 08:32 AM
skyline26's Avatar
the ones i got from a cobalt dont work on my HHR..there are two different kinds used on the HHR
TElphee
Aug 10, 2012 09:25 AM
LEWISXLOVE
Jun 27, 2012 08:01 PM
BlackknighT
Aug 19, 2011 07:15 PM
tracy waddell
Apr 29, 2011 04:54 PM
twatts28
Jun 28, 2009 07:59 AM
