Traction Control
Old May 27, 2019 | 05:05 PM
The TCM has nothing to do with the Traction control.
The transmission has nothing to do with TC.
There are other things besides a dirty screen that can cause the VVT solenoids to malfunction.
It is possible that the VVT SENSORS have a problem, since P0013 indicates that the cam position is not where the computer thinks it should be.
Could be a bad connection at the brake control computer; which is what controls the TC.
The likelyhood of the ECM having a problem other than a bad pin on a connector is close to zero.
Dealership shops suck
The causes of the traction control light are:
A. the button has been pushed to turn it off
B. a engine performance code is either "current" or "pending". A "current" code will cause the CheckEngineLight, a "pending "code does not.
C. a "pending" or "current" code will cause hard shifting, this has nothing to do with the TC
vrg813
Aug 25, 2018 04:27 PM
Lee3333
Jun 30, 2009 10:39 AM
Money in the Bank
Oct 19, 2007 12:26 AM
Whichfinger
Jul 22, 2006 11:30 AM
Adogg9626
Mar 4, 2006 08:55 PM
