Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
well i had my MAP sensor replaced.... didn't fix it.... then had the wheel bearing replaced (sensor inside).... also didn't work.... what is going on?!
Did you get the engine check light coming on? If so, what were the codes that were generated?
