Transmission
Old Nov 13, 2019 | 10:04 AM
Mike C's Avatar
Just an update. I replaced the transmission with a used one from a 08 and everything is working fine. I didn't have time to check the solenoids or pump but did check the lines in the pan and they were fine. Although the fluid was black, I didn't see a significant amount of metal shavings. I could have just replaced the filter and added fresh fluid but I doubt that would have solved the issue. The only hiccup I encountered was, upon an initial trial run, it was not shifting out of 2nd gear and was throwing all kinds of codes. One problem found was a loose connection at the front of the transmission and the second was the lack of fluid. The loose connection fixed some codes but the biggest improvement was achieved by topping off the fluid.
Now on to replacing the damaged/broken parts. I see on eBay listing that there are part number/placement diagrams such as below. Does anyone know where I can get a PDF version for the entire vehicle showing the part numbers?
Old Nov 13, 2019 | 10:36 AM
Look in the common parts forum.
Old Nov 13, 2019 | 10:41 AM
Cat Man HHR's Avatar
This is GM Parts Direct. I put in 2010 HHR LT
Just select what area of the car you want to look at.
https://www.gmoutletparts.com/v-2010...--2-4l-l4-flex
Old Nov 13, 2019 | 10:55 AM
Mike C's Avatar
Thank you Cat Man HHR, exactly what I needed.
Old Nov 13, 2019 | 01:20 PM
Just call me Cat for short, but never call me late for dinner.
Glad to help out.
Old Nov 13, 2019 | 01:59 PM
If you go to the common parts area you will find a link to an entire parts catalog in pdf. That might be too much trouble being it is exactly what you asked.
https://www.chevyhhr.net/forums/comm...rt-numbers-68/
Old Dec 13, 2019 | 10:06 AM
Mike C's Avatar
Finally back together. I replaced the VVT actuators but when I pulled the exhaust actuator, I discovered quite a bit of metal shavings. I don't have any check engine light anymore but I'm worried as to what the shavings are from. With that, I'm thinking I should just sell it. Any ideas as to what I should ask? It's in good condition with a few dents and paint issues but mechanically sound with 156000.
DJ Koz
2.2L Performance Tech
11
Aug 21, 2006 11:58 AM
Heartbeat
2.4L Performance Tech
Aug 15, 2006 08:51 PM
calgaryhhr
Jul 29, 2006 02:24 PM
BryceStrong
16
Jul 18, 2006 06:42 AM
nabate
May 22, 2006 10:36 AM
