Transmission fluid change - Form-a-gasket sealant?
Old Mar 30, 2020 | 11:17 AM
Cat Man HHR's Avatar
Originally Posted by guppy
If you torque a oily bolt, then you definitely way over torqued them. Torque values are always for dry bolts, I learned that one the hard way!
I don't know about that.
Built many engine(standard and torque turn) and everytime used a lubricant on head, main and rod bolt.
Let's put it this way, if there was a bolt and a hole(or a nut), lube went on it and I never had a problem.
50 plus years turning wrenches.
Old Apr 5, 2020 | 01:02 PM
slonny's Avatar
Transmission fluid is still leaking a little bit. All the bolts are torque to 89 in/lbs. The pan and gasket are new. All of the surfaces were dry during installation. Would that be a good idea to torque them to 106 in/lbs as suggested in this post (https://www.chevyhhr.net/forums/driv.../#post629239)?
Old Apr 5, 2020 | 01:28 PM
Gently, very gently tighten them as suggested.
Old Apr 6, 2020 | 03:01 PM
slonny's Avatar
Checked it today. It is still leaking at that one spot in the back. What options do I have at this time? I was thinking of slowly draining all the fluid, dropping the pan, cleaning everything real good including the bolts, applying silicon gasket maker (
Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker
), putting the pan back on and torquing it to 89 in/lbs.
I may have to do a lot of clean up in 100k miles...
Old Apr 6, 2020 | 03:12 PM
You might as well clean it up now, straighten out the pan flange and clean the surfaces really good!
Did you reuse the OEM gasket? Cork ones tend to leak, and neoprene ones don’t have the metal sleeves
Old Apr 6, 2020 | 04:21 PM
  #26
slonny's Avatar
I got ATP B-171 Automatic Transmission Filter Kit (
Amazon Amazon
). It did have the metal sleeve inside.
Old Apr 6, 2020 | 04:24 PM
  #27
slonny's Avatar
Maybe this is why... "The gasket came bent with a couple kinks in, rendering the gasket completely useless. I just reused the original one and there are no leaks to be found"
Just found this in one of the reviews. I had to straighten mine as well, because it had kinks in it.
Old Apr 6, 2020 | 07:58 PM
  #28
You mean the metal sleeve seal for the transmission filter, I mean the small metal pieces in the OEM pan gasket there should be 12 of them, did you keep the original gasket?
Old Apr 6, 2020 | 08:28 PM
  #29
slonny's Avatar
The actual gasket had a metal insert inside of it which made it bendable. It seems that manufacturer decided to just toss the gasket into a large box together with the filter and as it was shipped to you it would get bent out of shape making it unusable. Many people have complained about this problem on Amazon review of this product. There were no complaints about fel-pro gasket of the same type, so I guess these guys actually ship it attached to a cardboard so it doesn't get bent.
I got gray permatex sealant and will apply it ASAP to the existing gasket.
a_bartle
Maintenance and Upkeep
Jul 20, 2017 01:21 PM
aradmahogany
Jul 27, 2015 08:06 PM
Herbie
66
Jul 7, 2014 10:52 AM
bigjacksauto
Mods - Exterior
Jan 19, 2012 10:25 PM
BelizeBrian
Jan 23, 2007 11:28 PM
