Vibration at 50mph
Old Nov 15, 2010 | 09:50 PM
jgoldwood's Avatar
Vibration at 50mph
First, let me start by saying that I am not mechanically inclined. Does anyone else experience a pretty substantial vibration at around 50 mph. Up to that everything is smooth, and the same after, but at 50 there is definitely something going on. It is noticeable enough that as I am driving and not looking at the speedometer, I can tell when I hit 50 based on the vibration. Driving an '08 SS Auto. Thanks a bunch.
Old Nov 15, 2010 | 10:04 PM
pitbull76's Avatar
Does it go away at higher speeds? Or just get worse? Somewhere around 50 is where the torque converter kicks in and that can put out a pretty annoying vibration. Speeding up a bit/hitting the gas should silence that. Otherwise, if it is 50 on up, I would check your tires. I had a bad tire that caused a vibration at highway speeds... by the time I saw how bad it was there was a very noticeable bulge in the sidewall.
Old Nov 15, 2010 | 10:47 PM
I seldom venture over here because I'm a lowly normally aspirated guy, 2.2LS and 2.4 LT on order....but I'd check the tires first. You might be dealing with a converter chuggle, but I'd bet on the tires.
Old Nov 15, 2010 | 11:00 PM
geg's Avatar
geg
Definitely - the tire. read it. Very revealing.
https://www.chevyhhr.net/forums/problems-service-repairs-42/vibration-driving-over-45-mph-when-i-make-right-turn-frustration-32061/
Old Nov 18, 2010 | 08:39 PM
jgoldwood's Avatar
Thanks for the information. It does go away if I give it some gas. That is what I was trying to portray in the original post, that it seems to be right at 50 mph. It doesn't happen before or after that. I'll be at the dealership Saturday and see what they say.
Old Nov 18, 2010 | 09:14 PM
urbexHHR's Avatar
Sounds like it could be the tires need balanced maybe?
Old Nov 19, 2010 | 06:11 AM
pitbull76's Avatar
you have an auto, right? Right around 50 is where the torque converter kicks in and sometimes it can vibrate quite a bit if you are light on the gas. If you put it in I (which will keep the converter from engaging), does it still vibrate at 50mph? If not, it is probably the torque converter in the trans engaging and probably nothing to worry about. If it still vibrates when you hit 50 in I, it's probably a bad or out of balance tire.
fishing1151
Apr 23, 2014 02:23 AM
Oscarvan
Drivetrain (Excluding Engine)
Feb 20, 2013 08:26 PM
edgardop73
Tires & Wheels
18
Jan 17, 2013 04:38 PM
08LaRam
Jul 20, 2012 03:49 PM
jgoldwood
Oct 16, 2011 06:12 PM
