water in blower motor?
Old Jun 10, 2012 | 08:43 PM
joshua_arndt's Avatar
Originally Posted by whopper
Just cause the dealer fixed the patch once, doesn't mean it hasn't failed again. Best to check it as well - do not rule it out yet.
Very true... Guess i'll tear it apart next weekend.
Old Jun 10, 2012 | 08:44 PM
Originally Posted by 843de
Here's the thread, check out post #4 for pics of the condensate drain.
https://www.chevyhhr.net/forums/problems-service-repairs-42/water-dripping-onto-floor-36470/
Thank you that will help alot, what a good way to clean it out? how big around is the tube? Thanks for all the help guys, just trying to fix all the little things before we ship it over to germany.
Old Jun 10, 2012 | 10:48 PM
Cleaning it manually with a wire probe works, some folks will blow it out with compressed air(but you have to be careful), going from memory here...but I think the inside diameter of the drain is about 7/16".
Old Jun 10, 2012 | 11:58 PM
843de - didn't someone say you could see the butyl patch by removing the cabin filter and looking upward or something?
Old Jun 11, 2012 | 04:50 AM
You know I think you can see the patch that way, but I haven't found the thread with that reference yet, I'll do more searching later on this morning.
Old Jun 11, 2012 | 09:33 AM
If the cabin filter is wet it would point to the patch being the source of the leak.
Old Jun 12, 2012 | 08:36 AM
Originally Posted by joshua_arndt
For the past few months we have been noticing water in the blower motor casing maybe? Only reason i think that is because when we turn the corner we here the blower motor bog down and sound like its hitting water. and ocassionaly if we turn fast to the right the water comes out of someplace and drips on the drivers right foot on the pedal. any ideas? its getting annoying. and musty. This is on an 06 HHR
Thanks
Joshua Arndt
I have read the post about the vehicle being in the dealership about 40 miles ago for the work that 843de had mentioned. You might want to have them look at the work they performed. There should be a 12 month OR 12,000 mile warranty on this. If they find it is the repair that they had done then it should be covered under that warranty.
I hope you are able to get this resolved soon.
I have read on other forums I monitor about dealership having something to get rid of the musty smell you are experiencing.
I look forward to any updates you would like to share.
Old Jul 17, 2012 | 06:31 PM
Ok so i've cleaned out the drain the best i can... the water is still there... how hard is it to take apart all that stuff under the dash... the blower and the box that sits in between the driver and passenger side under the dash
kniffen
Mar 6, 2013 08:13 PM
Lee3333
Oct 21, 2010 09:09 PM
twistrman
Apr 27, 2010 06:39 AM
