Waterleak in floorboard
Old Sep 19, 2010 | 05:08 AM
linmoody's Avatar
I bought a new 2007 HHR and a couple days ago had the water leak in the passager foorboard,Saw what everyone said to check so my husband checked under the cowl where the butyl patch is suppose to be and theres not one there. Don't understand why it has'nt leaked before in 3 years and it's making noise when I turn left or right.To me it seems like it's ac water coming out.But the other day it did rain and had about a half gallon dripped out but it's still leaking but not as much. You think chevy will put a patch on since I don't have one? Thanks
Old Sep 20, 2010 | 12:33 AM
Welcome-
Do you have a sunroof ?
And IIRC ? 2006 & '07 only had need of the patch, which was an access hole to get in there..
it was later re-designed, & done away with.
Read this link for more info:
https://www.chevyhhr.net/forums/show...ht=butyl+patch
Old Sep 20, 2010 | 08:02 AM
linmoody's Avatar
No sunroof. Are you saying theres no patch on the 2007? It's making noise when I turn left or right too.Thanks L
Old Sep 20, 2010 | 09:07 AM
Zagohhr's Avatar
What kind of noise are doing? Humming, grinding, a noise like the wheel is hitting the inner well?
Old Sep 20, 2010 | 09:10 AM
masterchief1112's Avatar
there should be a patch there. if you still have bumper to bumper which you might it needs it. the humming if its when you turn hard right or left the tire is prolly rubbing
Old Sep 20, 2010 | 07:37 PM
linmoody's Avatar
It does'nt sound like a tire more like it's coming from the ac vents.
Old Sep 20, 2010 | 08:19 PM
J W Davis's Avatar
Sounds like the blower motor bearings ( I mean bushings) are shot, letting the fan hit the blower housing during hard turns. As to the water.... well probably the AC condensate drain line is plugged up with gooo and I belive there is a thread about that in here somewhere.
Just a thought.
daddy2isaiah04
Mods - Interior
10
Dec 20, 2012 04:07 AM
Gcort49
Sep 30, 2009 09:44 AM
foolmoon_design
Jul 6, 2009 12:41 PM
tcstoy
Sep 13, 2008 08:55 PM
Sunrise HHR
Aug 14, 2008 12:55 PM
