Wet floorboard again!!!!!!!!!!
Old Sep 13, 2008 | 06:19 PM
tcstoy's Avatar
Angry Wet floorboard again!!!!!!!!!!
After fighting water in the passenger front floorboard area and fixing that problem...........now the passenger back floorboard is getting wet. The front is dry now and the "boots" for the wires in the door jambs seem to be seated correctly. The seal around the door seems to be in good shape. Anybody else have any problem with their backseat floorboard area taking on water? This is getting old trying to keep the floor dry.
Old Sep 13, 2008 | 06:30 PM
Goose's Avatar
Inexcusable imho...if my HHR ever started to leak like that it's a goner
That being said let's hope it doesn't as the car is pretty cool lol
Goose
Old Sep 13, 2008 | 08:31 PM
stick's Avatar
I had a wet floor in the front once. If it happens again it's going to the dealer. If that gets fixed, then the rear gets wet, back it goes. They will fix it, flood it, and repair it, till it is right. If they can't get it they can buy it back and sell me a new one. That just has to be a mess under the carpet and we shouldn't have to put up with it.
Do you by chance have a sunroof that might be leaking?
Old Sep 13, 2008 | 08:52 PM
a hhr's Avatar
check the rubber gasket on the passenger side under the wiper cowl.
it can also make ur fan speed go out
also if you have roof rails the screws or bolts can come loose and leak down the sides and you feel the seatbelts get wet in the inside of the column
an08HHR's Avatar
Read this thread, there is mention of wet rear floor in one of the post. Hope it helps. https://www.chevyhhr.net/forums/show...=sunroof+drain
Old Sep 13, 2008 | 08:55 PM
JonyyB's Avatar
^ Yes, I hear the sunroof drain is often the cause of wet interior floors.
daddy2isaiah04
Mods - Interior
10
Dec 20, 2012 04:07 AM
linmoody
Sep 20, 2010 08:19 PM
Gcort49
Sep 30, 2009 09:44 AM
foolmoon_design
Jul 6, 2009 12:41 PM
Sunrise HHR
Aug 14, 2008 12:55 PM
