Window Regulator issues
Old Jun 8, 2015 | 10:41 PM
Cascious King's Avatar
So I powered my window down and now it wont go back up. I had heard it making some slipping noises prior to this so I thought for sure I needed a new regulator. I bought a new one and installed it but the window still doesn't go up or down! Im looking to get a wiring diagram now and hope to do some voltage testing tomorrow.
MY ISSUE / QUESTION. Since this is going to be a little time before I can diagnose the problem and actually fix it, How can I power the regulator so the track goes to the up position....then I can take my time to figure this out. Can I somehow do it on my workbench with a battery? I took it out again to prop the glass up so it's closed. It obviously can't stay like this. I mean I suppose theres a chance the new one is bad, but I highly doubt it. Bench testing it will eliminate that question too.
thanks
CK
2009 hhr panel. Drivers side window works jus fine. When I hit the switch I hear a click at the passenger switch...tells me power is getting there
Old Jun 9, 2015 | 06:06 AM
Lucky's Avatar
Bench testing is fairly easy with a battery. The window motor is just a 12 volt DC motor.
Two wires hook up one way the motor turns in one direction reverse the wires and the motor will turn the other direction.
Be carful there are lots of pinch points for your fingers when the regulator is moving
Old Jun 9, 2015 | 06:09 AM
I don't suppose you checked the switches first? If power is getting to the motor, there is either a jam or a bad motor. There is most likely a limit switch somewhere in the circuit, just guessing.
12V is 12V whether it's in the car or on the bench.
Check your PM.
Old Jun 17, 2015 | 11:19 AM
thanks guys. I'm kind of thinking my new regulator/motor was bad since neither new or old worked bench testing. I was thinking perhaps I was missing something during bench testing but it appears not. I know it seems improbable but its seeming the case at this point...just bad luck.
I'm going to take my time in a day or so and go through it all one more time before I buy another one. Now that I have proper documentation to go by.
Old Jun 17, 2015 | 11:24 AM
I did check the switches but neither one operates it, I can't see both switches going bad at the same time. Pretty sure I checked power everywhere I needed to and got 12, I was quickly doing it though and could have easily missed something. The day this happened was a rainy day of course so evertything was done in haste.
The windows been wedged up ever since...time to get at this properly
Old Jun 17, 2015 | 12:04 PM
Give this thread a read. Hope it helps
https://www.chevyhhr.net/forums/prob...-switch-46384/
Fievel4
Fuel Economy - Hypermiling
Jan 5, 2015 03:42 PM
car nut
Dec 3, 2013 06:32 PM
Carnage SS09
Jun 10, 2013 12:37 PM
scbill
Mar 6, 2013 12:51 PM
BLUEHHRSS5SPEED
Dec 19, 2010 08:46 AM
