Upgrading base h/u
Old Jun 21, 2012 | 07:29 PM
8thmileman's Avatar
Upgrading base h/u
I want to upgrade from base h/u to the one with equalizer. I've read that dealer programming is needed. Is this so, or is there a way around the dealer?
David
Old Jun 21, 2012 | 09:26 PM
Yeah David, if you go from the base head unit to the singe CD/MP3 or the multi disc CD/MP3 head unit, you have to head to the dealer for programming. The head units are an integral part of the GM LAN system that interconnects all the electronic "guts" of the HHR.
The going rate seems to float around $60-80 for the service, but unless you have a scan tool with the proper capabilities and the service manuals, its not a DIY proposition.
Your other alternative is to go with an aftermarket head unit and adapter harness to let it talk to the HHR, no programming required in that situation.
Old Jun 21, 2012 | 10:08 PM
EcotecRacer's Avatar
yep whay he said go aftermarket the "upgrade" units are junk the eq settings are at horrible parametric frequencies
Old Jun 22, 2012 | 10:28 AM
8thmileman's Avatar
OK, thanks guys!
Strikes4Days
14
Mar 26, 2015 05:33 PM
gio89kid
Apr 20, 2014 07:29 AM
Lowboy44
Jan 31, 2014 04:21 PM
TAK
0
May 10, 2012 07:53 PM
wxman
Jun 30, 2008 10:35 PM
