2009 SS Clutch Slave Bleeding
Old Apr 7, 2020 | 02:43 PM
OshawaHHRss's Avatar
Originally Posted by rorr
Hi Guys,
Thanks for the quick reply. Unfortunately, the job is already finished and I'm left trying to sort this out with it all back together and running (albeit not 100%).
Pre-filling the slave cylinder would have been great information to know before it all went back together, but I've never seen that mentioned anywhere in the GM service manual, or online in any of the other videos or threads I read. I've attached the GM service manual procedure for grins.
Maybe I can get me a syringe and a very small hose that will snake down into the slave cylinder and I can slowly fill it up from the bottom that way.
Again, thanks for the quick replies and the advice. I still love driving this thing. It's not the fastest car I own, or the 2nd fastest, but it is a hoot to drive, nonetheless!
Sincerely,
Robert
Prefilling it was advice given to me by Powell. Saves a lot of frustration. Just bleed it normally, you should be fine
Old Apr 7, 2020 | 06:57 PM
rorr's Avatar
Thanks all for the replies and for trying to help me figure this out.
Yep, the GM manual only refers to what appears to be the standard 5 speed, not the MU3 (SAAB) manual transaxle. But, the components are similar (bleeder screw is still outside of the bell housing), and I'm sure (in the GM engineers eyes) the procedure is similar. There is still no bleeder screw at the slave cylinder for the standard HHR 5 speed, so, how does GM expect you to get the air out of the slave cylinder?
I truly don't believe applying a vacuum at the reservoir is sufficient. That is why I inquired here. Shade tree mechanics are usually MUCH more creative and resourceful than corporate engineers (believe me, I work in the service division of a world renowned OEM, and we do not have all of the answers).
I am curious, if anyone has performed this job, was prefilling the slave cylinder before installation what made this repair work? I just took it for another drive, after applying a vacuum at the reservoir a couple more times, and still the same results...
I really just want to finish this repair, so, if that means getting fluid into the slave cylinder by some other method than what GM says, I will do it. I'm just hoping for another option that doesn't require me tearing it apart again. Thanks again for keeping the conversation going.
Sincerely,
Robert
Old Apr 7, 2020 | 07:32 PM
I just put in a new engine, clutch, and TOb/slave. I used my AAA towing benefit to tow it to my favorite shop. They charged me half hour labor, and a little bit of brake fluid, to bleed the clutch. I did not prefill the slave, I have had no problems with the clutch so far(200 miles).
Old Apr 7, 2020 | 10:11 PM
Sincerely,
Robert
if I were you, I would bleed it just like you bleed brakes. You should be able to get all the air out eventually. If you tear it apart again, just prefill it
Old Apr 8, 2020 | 11:17 AM
rorr's Avatar
I would love to bleed it like I do the brakes, but the bleeder screw is not the last link in the chain of items as the fluid moves away from the master cylinder. Prefilling it seems like a logical need when performing this job, I am just really baffled why GM doesn't say to do that when replacing the slave cylinder. Oh well...
The reason for me starting this thread was to seek out someone here that has performed this exact job on an SS and has successfully bled the clutch, so I could learn what I did wrong and get my clutch up to 100%. I don't want to tear it down again to properly bleed my clutch, but, I will if that's what I have to do.
Thanks for the info guys, and keep it coming, if anyone has anything to add.
Sincerely,
Robert
Old Apr 8, 2020 | 10:00 PM
Sincerely,
Robert
I’ve bled it before with just the bleeder screw. You can get good feel by it, it just takes longer
Old Nov 4, 2020 | 02:09 PM
liflod's Avatar
I'm going through the same problems after replacing the clutch and slave cylinder. The statement "GM states to put about 15 inches of mercury vacuum on the reservoir" is correct.
I just did some research on dry vacuum bleeding and that is how its done if you dont have a bleeder at the end of the line.
Here's a couple links.
http://​​​​​​​:https://images.oreill.../ptq/ib195.pdf
http://www.clutchmasters.com/content/clutchBleeding.pdf
I'm going to pick up a new reservoir cover to add a fitting for my vacuum pump.
I'll let you know how it works.
Old Nov 9, 2020 | 06:59 AM
liflod's Avatar
It didn't work out for me. There is some type of reservoir after the master cylinder that allows air to be drawn into the system when I apply vacuum to the main reservoir. I tried taping the vent closed, and I did get bubbles in the main reservoir, but the clutch is still engaging right at the floor.
Old Nov 9, 2020 | 07:16 AM
Apparently, vacuum is to be applied at the bleeder and not the reservoir cap.
https://www.saabcentral.com/threads/...clutch.613610/
these Saab guys seem to have it figured out
https://www.google.ca/search?q=bleed...&client=safari
Blue_SS
Drivetrain (Excluding Engine)
15
Jun 16, 2022 04:24 PM
Pat Kelly
10
Aug 17, 2018 06:56 PM
renegade10
Feb 2, 2011 11:23 AM
Cpt.Carnage
Aug 30, 2010 03:57 PM
ghrtfldr
Apr 7, 2008 03:28 PM
