Clutch Sensor
Old Dec 2, 2019 | 05:35 PM
Trouble codes are the letter followed by 4 digits. So it's P0806.
Old Dec 2, 2019 | 05:42 PM
That code indicates a problem, you replaced the sensor switch, now that’s not it.
next is the wires, a loose or broken ground wire would be my guess
https://www.obd-codes.com/p0806
Old Dec 2, 2019 | 08:59 PM
Originally Posted by BadLILSS
I already had the positive wire replaced from the front to the back and the battery what a treat those are to replace!
A. Why? I can't think of a reason.
B. Why are you posting one sentence at a time? No extra charge for paragraphs and carriage returns.
C. P0806 indicates the Cluitch Position sensor Signal wire is compromised.
My previous advice stands. Along with insuring the Lt-Green wire is intact between the clutch pedal and the ECM, but all 3 need to be checked.
Old Feb 9, 2020 | 07:11 AM
Marc Guay's Avatar
would you know what wires I could jump out to trick the computer so I can drive it today? Part is on order. And it’s my only car.
Old Feb 9, 2020 | 08:40 AM
I would try grounding the lt.green wire in the plug. Disconnect the connector and run a wire from ground to the lt.green contact in the harness. Or, jump the lt green to one of the other wires one at a time.
The switch is a variable resister with 5V on the dk blue/white wire and ground on or/grn. I would try A to B first then C to B, if neither works ground B. Don't ground C or you will short the ECM.
Seems to be some different color codes, here is the connector pins.
Old Feb 9, 2020 | 09:01 AM
  #26
Marc Guay's Avatar
oh dude. Thank you! Gonna try this immediately
Old Feb 9, 2020 | 09:15 AM
  #27
Marc Guay's Avatar
nope didn’t start. But thank you very much !
Old Feb 9, 2020 | 09:30 AM
  #28
Your profile shows that you have a 2008. This is the SS forum, do you have an SS? The SS has a clutch pedal position sensor, the LS/LT did not, in 2008.
Old Feb 9, 2020 | 12:00 PM
  #29
I did not know that. The wiring diagram shows it for all.
Old Feb 9, 2020 | 12:44 PM
  #30
I think you're right, looks like the change for 2008 affected all trim levels. My mistake.
