Code P2178
Old Jan 17, 2020 | 05:30 PM
  #41
Cat Man HHR's Avatar
Originally Posted by dsomonster
Cat Man, what is the interior diameter of our outlet duct that attaches to the turbo? I am not sure the duct will fit over this piece since the fit to the turbo is snug. The hose is 5mm thick and I don't think the duct has that kind of play.
What do you think?
ID of rubber tube is 2 1/2"
You won't get into trouble using this item I showed.
Re look at what I posted that I found on Ebay.
Reread the measurements I gave you off the OEM flex joint also.
Old Jan 17, 2020 | 05:31 PM
  #42
Originally Posted by donbrew
You didn't actually say "silicone hose"
The link I posted said silicone hose.
Really you could use a straight piece of radiator if need be.
jknezek
Oct 1, 2019 03:18 PM
Cliffs51
Maintenance and Upkeep
Aug 25, 2018 02:29 PM
hurst2001
Jun 22, 2018 12:30 PM
jdcowboy
Sep 8, 2014 05:16 PM
voigtsga
Aug 22, 2014 05:29 PM
