Cooling fan operation
Old Jul 20, 2012 | 01:04 AM
Originally Posted by whopper
..... Waiting to see if someone posts a question asking if the speed can be overridden so that the fan runs at 100% to help pull the car through the air faster - sorta like a turbo fan thing.............. Over to you Bigjacksauto ;-)
Did a few quick and dirty calculations based on the approximate 1/3 hp developed by the cooling fan motor on an HHR, with the fan diameter and pitch also factored in.
On a "Standard Density" day (Density (ρ): 1.229 kg/m³-Pressure (p): 101.3 kPa-Temperature (T): 15 °C-Viscosity (μ): 17.3 µPa·s), the fan will develop approximately 7.63lbs of thrust at 1,725 rpm.
Not enough to matter really, now bolt a P&W J-58 Turbo-Jet on the roof, that's another matter entirely.
Old Jul 20, 2012 | 01:10 AM
You got a part # on one of those, would it fit under a cowl hood ??
Old Jul 20, 2012 | 01:17 AM
I don't think room under the hood would be an issue, it won't fit, and you might burn the paint off the guy's car behind you.
That 32,500lbs of thrust and 160,000 horsepower at work there, simply awesome!
Old Jul 20, 2012 | 06:42 PM
Mr Z's Avatar
Originally Posted by Vcode455
Can anyone tell me what temp the cooling fan is supposed to come on at? Mine seems to run almost continuosly. 2009 SS Auto with GMTU. Watching the digital temp, it runs between 190 and 198. Fan seems to always be on when I am stopped, even with the A/C off. I can let it run at idle and it does not turn off, even after a run on the highway with outside temps around 80. Is this normal?
I wish mine would stay that cool.
Old Jul 24, 2012 | 10:08 AM
Actually, Michelle answered my question. Thanks Michelle!
My resources have informed me that your vehicle with the 2.0 turbo engine has the fan that will run all the time. The fan speed is controlled at between 10% and 94% (high speed) so the speed will vary but it may never shut off completely. This is different than the non- turbo engine which will actually turn off at times.
You're VERY welcome!!! It was a huge pleasure to help out with this. Please, don't hesitate to contact me in the future.
Old Jul 24, 2012 | 10:13 AM
Michelle -
Thanks, whopper!!!!
Old Aug 5, 2012 | 10:25 AM
REDSEDANDELIVERY's Avatar
yes you can but the extension cord has to be really, really, really long.
ManWagon
Jul 18, 2012 08:47 AM
fonemann
Mar 19, 2012 08:55 PM
BlackHHR06
Jan 14, 2010 06:46 PM
joeblue
Sep 10, 2009 11:32 AM
djnixtre
14
May 14, 2009 04:09 AM
