Fuel Pressure
I said swap...... I guess I should have said RWD into a streetrod.
I have the LNF already, plus more wiring and connectors than I will ever need.
I will be builing my own harness and bolting the engine to a 4L60E trans with a custom LNF adapter (Oil cooler needs to be retained, but relocated) I am designing and having CNC machined. The trans will run off of a TCI TCU unit which will give me 2 performance levels and Vince at Trifecta will be doing the tuning and vats removal for me.
Ok guys, ChevyMgr says 50-60.
I know that the Corvette LS2 filter with built in regulator runs at 58psi.
My next step is to buy, and hook up a diagnostic fuel pressure gauge on my SS to see what it is actually running.
hoping I can get away from the in tank regulator and use the LS2 filter with a wolbro in tank pump.
Update
Ok a while back I did get the fuel pressure tester. Hooked it up to my SS and found that the pressure is right around 58 Lbs. at the fuel rail. I know on LS swaps the pressure is the same so I nailed it. High pressure intank pump with a Corvette filter with built in regulator and return.
so for those of you thinking of an LNF Swap into your LS there is a little info for you.
The trans adapter is out being CNC machined after the initial water jet process.
