High rev at idle after map and maf change
Old Sep 26, 2022 | 01:02 PM
  #31
I fixed that for you.
Old Sep 27, 2022 | 11:16 AM
  #32
jcs_ss_panel's Avatar
thank you!!
Old Oct 9, 2022 | 04:39 AM
  #33
Originally Posted by greg8453
Has it learned idle?
Now I have these again
Old Oct 9, 2022 | 08:37 AM
  #34
Have you:
cleaned the throttle body?
Checked the engine coolant temp?
done a compression test?
Cleaned the fuel rail?
Checked both fuel pressures?
Checked the EVAP purge valve?
The misfire is probably causing the P2187.
Old Oct 9, 2022 | 09:35 AM
  #35
Cleaning the throttle body is a bit of a job on the LNF, as is cleaning the fuel rail. I would start with donbrew's other suggestions first.
I don't see that you've mentioned how many miles are on the car. The intake valves might be coked. The compression test would be the first step in diagnosing that, followed by a cylinder leak down test.
Old Oct 9, 2022 | 05:40 PM
  #36
Originally Posted by donbrew
Have you:
thank you!! Lots of things to try for me then
filmcriticwife
May 14, 2020 07:40 AM
tarchie
Aug 11, 2015 04:34 AM
fonque
0
Jun 1, 2015 12:20 AM
bluwing
Oct 30, 2014 05:34 PM
Lee3333
2.4L Performance Tech
Aug 1, 2008 02:27 PM
