Lots of oil in cyl #3
Old Feb 16, 2020 | 01:39 AM
  #91
Dark_Knight's Avatar
Guys guys hey guys lol
It's done. It runs pretty good. Needs some calibrations done and a wheel bearing but man it's so nice to drive a car that dont bang tick and click with every movement. I'll get a video of it running tomorrow. Still gotta burp the cooling system. But man I'm so greatfull.
Old Feb 16, 2020 | 05:51 AM
  #92
Old Feb 16, 2020 | 07:21 AM
  #93
Awesome! Yes burp that coolant, an air bubble can cause problems if left unchecked
Did you find the brake master cylinder cap?
Old Feb 16, 2020 | 09:28 AM
  #94
I had to buy a new one. I ripped the garage apart and didnt find it. Think maybe my son threw it away trying to help clean one time.
Old Feb 16, 2020 | 11:22 AM
  #95
Cat Man HHR's Avatar
Dark Knight
What calibrations does it need ?
Do you have a code P0315 ? Crank sensor not learned.
Thanks
Old Feb 16, 2020 | 11:40 AM
  #96
Originally Posted by Cat Man HHR
Dark Knight
Thanks
I'm mostly getting suspension and steering codes. I'm sure the steering code is it just needing to be calibrated. The traction control is likely the wheel bearing.
Old Feb 16, 2020 | 11:47 AM
  #97
The reason I ask is because there is another post about a used engine install and there is a crank sensor fault.
You cleared that up because you have a used engine installed and don't have that code.
Old Feb 17, 2020 | 06:10 PM
  #98
understandable. I did end up with a and b cam sensor codes. But that should be just a relearn.
Old Feb 18, 2020 | 02:13 AM
  #99
Pull the two sensors and check to see if the screens have crud on them.
If so clean the sensors and reinstall, see if the codes go away.
I say this because the norm is to replace them and maybe all they need is to be cleaned due to dirty oil from extended oil changes or poor grade oil.
Old Feb 18, 2020 | 12:51 PM
  #100
I'll give that a shot tonight. I also have the old sensors from the original motor.
Plus a relearn may help. Needs spark plugs as well but I'll handle that in a couple weeks.
This car is a beast. After driving a few days I finally got into the throttle. Blew the tires of as it hit 25psi.
