P0234 code
Old Aug 17, 2016 | 08:21 PM
  #31
This motor has a designation LNF, and is shared by Cobalt SS, Saturn Sky Red Line, and Pontiac Solstice GXP. You may have been typing when I just posted some links.
Old Aug 18, 2016 | 07:44 AM
  #32
DrLoch's Avatar
Heres a link for a waste gate solenoid Buy GM 55557806 Valve, solenoid, turbocharger wastegate actuator vacuum control, genuine OEM part
Hereis another, BorgWarner EFR Boost Control Solenoid Replacement Kit - Full-Race.com
Old Aug 18, 2016 | 08:22 AM
  #33
I just noticed they want 1.5 hours for the VVT valves.
The extra exhaust gaskets are the air gaskets.
From Mitchell: Include R&R of air filter. Looks like they don't know how to read the flat rate book. That labor is almost right for the Camshaft Position SENSORS. And no reason given for the work. I don't trust them, they are throwing parts at your car.
Old Aug 18, 2016 | 07:12 PM
  #34
Has anybody used oemcats(first link)? Not sure I trust it, seems like maybe some kind of classified ad or something. This one is in Moscow, shipping would probably kill the deal.
The other one is the same that I linked to. Does anybody think it should go in the common part thread? BorgWarner 179425 if anybody wants to shop around.
Old Aug 22, 2016 | 12:11 PM
  #35
OKIE SS's Avatar
Update: Took the HHR to an independent and he's replacing just the solenoids - says everything else is fine. $360 with oil change vs $3000 from Chevrolet.
Old Aug 22, 2016 | 12:14 PM
  #36
Wow $230 an hour labor!
Old Aug 22, 2016 | 12:23 PM
  #37
OKIE SS's Avatar
We'll see what's labor and what's parts.
Old Aug 22, 2016 | 03:04 PM
  #38
You posted the prices; $66.53 each. Parts $133.06, labor for both 1.1 hours.
Oil changes with M1 probably around $50.
If you meant to include the 2 turbo parts that's about $100 according to the links posted.
That makes a difference, but you said "just the solenoids" which I took to mean the VVT valves., and we have heard of shops charging that much. I was advising to look closely at the estimate.
Old Aug 22, 2016 | 07:03 PM
  #39
Yes, I agree, find out which solenoids. The solenoids your dealer wanted to replace shouldn't have anything to do with an overboost code. You should only be looking at the boost control solenoid or the electrical connector for it.
terryk
30
Jan 1, 2015 09:26 PM
LtGhost08
Jun 10, 2013 02:13 PM
foolmoon_design
Mar 10, 2013 12:19 PM
missbecky
Mar 12, 2012 05:08 PM
SSROADSTER
12
May 21, 2010 10:31 PM
