Possible fuel pump issue
Old Jun 3, 2019 | 05:12 PM
Again, please have your battery load tested.
Old Jun 3, 2019 | 05:14 PM
Yes. Please clear things up. Your 1st post says:
"Just ran pressure test
Started at 64 lost 6lbs after 5 minutes".
So, did it start up or not ? Last post says will not start. Which is it ?
Old Jun 3, 2019 | 05:46 PM
Test #1 ignition ON engine OFF, force fuel pump on pressure should be 50-60 PSI
turn pump off
If the pressure decreases by less than 5 PSI in 1 minute the pump is bad.
If it decreases by more than 5 PSI in 1 minute there is a leaking injector.
Test #2
Relieve the pressure to 10 PSI, if the pressure decreases by more than 2 PSI in 5 minutes the fuel pump is bad.
The pump will only run for a few seconds with engine off, so you need to either use a scantool or lie to the relay.
Old Jun 3, 2019 | 08:39 PM
mclc126's Avatar
Ok thanks for the test tips Donbrew. We will try those over the weekend and let you know
Old Jun 5, 2019 | 10:30 AM
Wow. Looks like my last post was ignored. Just trying to get some info/facts so I could give some accurate help.
Guess I'm out.
Old Jun 5, 2019 | 06:54 PM
I’m with you FMG , over and out.
Old Jun 10, 2019 | 05:07 PM
mclc126's Avatar
turn pump off
Test #2
Tried test 1 & 2 and the Fuel pump pressure passed. But the car still will not start.
Old Jun 10, 2019 | 05:17 PM
Since this is exactly the symptom that the recall is supposed to fix, has it been done?
Does the motor turn over?
Has anybody checked the timing chain?
Old Jun 10, 2019 | 05:44 PM
mclc126's Avatar
Yes all recalls are up to date. Motor turns over. Thinking of checking timing chain next.
Old Jun 10, 2019 | 06:17 PM
Yep, back to basics, compression test, check for spark, etc.
